avec l ancien biosHP ProBook 650 G2. 6050a2723701-mb-a02 avec fichier bios corrompu le pc va en veille prolonge
the bin in question is not in good condition the PC turns on without display
Indeed it is the same as the old biosthat file is tested working !
does it have same result like old bios ?
In fact it is the same as the old bios but only that what you sent makes the fan run strongly and the pc displaysthat file is tested working !
Obviously it's the same copy as the old BIOS but it doesn't always workcheck hardware carefully
It's done because with the new bios it doesn't always work but as soon as I put the old bin file back the PC turns on and with the same errors as at the beginningthat file is tested working !
user51023 , Salimeh Bolboli , Vahab Hemmati , user49177 , user46647 , Atalakou , adham
